はじめに
Use when the USB port needs to be removed. (Soldering Required)
必要な工具と部品
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Gently lift the rear casing from the device.
The Astro Mixamp Pro is largely the same process as this, except there are some plastic tabs on the rear casing holding it onto the front plate. Carefully work along the seams on the long sides and the corners with something flat and stiff, gently levering the rear housing out and away from the front plate to disengage the plastic tabs. With enough patience and care, they'll pop out of their spots and the casing will be free.
Press the tip of a hot soldering iron to the USB connection to melt the solder.
Use a nylon spudger to lift the USB from the solder.
Repeat for each of the four USB connections.
2 の人々がこのガイドを完成させました。
4 件のコメント
What port is used as a replacement?
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
MoreZemtor - 返信
Will this method work with the 2015 tr mixamp?
