メインコンテンツにスキップ
Archos 97 Carbon Speakers Replacement
必要な工具と部品
  1. Archos 97 Carbon Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Pry the tablet open in the corner using an opening tool.
    • Start in the top left corner and continue clockwise until the two pieces are separated.
  2. Archos 97 Carbon Speakers Replacement: 手順 2、 3の画像 1 Archos 97 Carbon Speakers Replacement: 手順 2、 3の画像 2 Archos 97 Carbon Speakers Replacement: 手順 2、 3の画像 3
    • Remove the tape and plug connecting the cable to the tab, and it will come loose.
    • This will loosen the cable connecting the screen to the interior of the tablet.
  3. Archos 97 Carbon Speakers Replacement: 手順 3、 2の画像 1 Archos 97 Carbon Speakers Replacement: 手順 3、 2の画像 2
    • Remove the black tape from the silver cable connecting the screen to the motherboard on the left side of the tablet.
    • This will loosen the gold plug.
  4. Archos 97 Carbon Speakers Replacement: 手順 4、 1の画像 1
    • Once you have separated the the screen from the tablet, you can place the screen to the side. You should be looking at this part of the tablet.
    • These are the speakers.
  5. Archos 97 Carbon Speakers Replacement: 手順 5、 3の画像 1 Archos 97 Carbon Speakers Replacement: 手順 5、 3の画像 2 Archos 97 Carbon Speakers Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    • Desolder each of the three wires to detach the speaker wires from the tablet.
    • There are three wires that you will desolder from the motherboard. One is red, one is black, and one is white.
    • We recommend that you use a solder sucker to suck up any of the residue that the solder produces.
  6. Archos 97 Carbon Speakers Replacement: 手順 6、 2の画像 1 Archos 97 Carbon Speakers Replacement: 手順 6、 2の画像 2
    • Pry each of the speakers up with an opening tool.
    • Remove the speakers and their connected wires from the tablet.
終わりに
You have now successfully replaced the internal speakers for your Archos 97 yourself. And now you understand the process for accessing and potentially repairing/replacing any other internal components in the future should the need arise.
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Allyson Seber
メンバー登録日: 03/03/15
311 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 13-5, Blackburne Winter 2015 Sam Houston State, Team 13-5, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S13G5
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 470
