メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will help you repair a loose headphone jack on your Archos 5 tablet. Although this repair may take some time, don't be discouraged. You can do this yourself!
  1. Please be sure that your device is powered off before attempting any repairs.
    • Please be sure that your device is powered off before attempting any repairs.
    • Please be aware that any further steps could possibly void the warranty of your Archos 5.
  2. Use the plastic opening tool to take off 3 black sticky pads that cover the screws. Use the screwdriver(PH000) to remove the screws located under the pads. One of the screws is located under the stand.
    • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
    • Use the screwdriver(PH000) to remove the screws located under the pads. One of the screws is located under the stand.
    • Lift the stand in order to get to the fourth screw.
  3. Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool. Once all sides of the device are priced open, gently open the device.
    • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
    • Once all sides of the device are priced open, gently open the device.
    • Be careful not to tear the foil which connects the LCD screen to the motherboard!
  4. Once you have opened your device, fold the screen away from the battery. Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece (attached at the bottom of the metallic foil.) Press the plastic spudger against the thin black piece and  release it.
    • Once you have opened your device, fold the screen away from the battery.
    • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece (attached at the bottom of the metallic foil.) Press the plastic spudger against the thin black piece and release it.
    • Use a plastic spudger instead of a metal spudger!
  5. Once you have unplugged your screen, locate the headphone jack.
    • Once you have unplugged your screen, locate the headphone jack.
    • If you are looking at the right side of the device, the headphone jack is located in the mid-upper corner (as shown by the red box).
    • The headphone jack is a black rectangle-like shape.
  6. Cut a small piece of electrical wire that is long enough to reach the ground connectors  on each side of the headphone jack. The wire MUST go AROUND  the connector for the device to close properly.
    • Cut a small piece of electrical wire that is long enough to reach the ground connectors on each side of the headphone jack.
    • The wire MUST go AROUND the connector for the device to close properly.
  7. Hold the electrical wire with tweezers and begin soldering each end of the wire to the two ground connectors. If you do not know how to solder, follow this link to learn how! How To Solder.
    • Hold the electrical wire with tweezers and begin soldering each end of the wire to the two ground connectors.
    • If you do not know how to solder, follow this link to learn how! How To Solder.
    • Do not wait too long while soldering or else you may damage your device.
終わりに
2 の人々がこのガイドを完成させました。
Ally Hummel
メンバー登録日: 2015年09月22日
375 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 1-5, Sydow campbell Fall 2015 University of Alabama, Team 1-5, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 652
