メインコンテンツにスキップ
Apple iPod Dock Connector Cable Replacement
必要な工具と部品
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: 手順 1、 3の画像 1 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: 手順 1、 3の画像 2 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: 手順 1、 3の画像 3
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: 手順 2、 1の画像 1
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: 手順 3、 1の画像 1
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: 手順 4、 1の画像 1
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: 手順 5、 1の画像 1
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: 手順 6、 1の画像 1
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: 手順 7、 1の画像 1
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: 手順 8、 2の画像 1 Apple iPod Dock Connector Cable Replacement: 手順 8、 2の画像 2
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
  10. Apple iPod Dock Connector Cable Replacement: 手順 10、 1の画像 1
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fume—do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: 手順 11、 2の画像 1 Apple iPod Dock Connector Cable Replacement: 手順 11、 2の画像 2
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: 手順 12、 1の画像 1
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: 手順 13、 2の画像 1 Apple iPod Dock Connector Cable Replacement: 手順 13、 2の画像 2
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
終わりに
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
作成者
2人の作成者と共同で作成されました。
Anoniem
メンバー登録日: 03/08/17
19 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 22
今までの合計 475
