メインコンテンツにスキップ
Apple TV 3rd Generation Power Supply Replacement
必要な工具と部品
  1. Apple TV 3rd Generation Power Supply Replacement, Snap-on Base: 手順 1、 1の画像 1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Power Supply Replacement: 手順 2、 1の画像 1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Power Supply Replacement, Logic Board: 手順 3、 1の画像 1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Power Supply Replacement: 手順 4、 2の画像 1 Apple TV 3rd Generation Power Supply Replacement: 手順 4、 2の画像 2
    • Disconnect the power supply connector from the logic board with a spudger.
  5. Apple TV 3rd Generation Power Supply Replacement, Power Supply: 手順 5、 2の画像 1 Apple TV 3rd Generation Power Supply Replacement, Power Supply: 手順 5、 2の画像 2
    • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • Do not pull the wires to remove the power supply. The connector is fragile.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
終わりに
14 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Vincent Monteil
メンバー登録日: 07/06/13
7,023 ポイント
19のガイドは作成済み
11件のガイドコメント
you forgot to add the power supply is held by 2 tiny torx screw
morpheuse - 返信
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
rcbakes30 - 返信
Where? I need on badly! Can you send me / Post here a link?
jakesterage -
please, and where could be find the part, the power supply for AppleTV 3rd generation?
foxy72 - 返信
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
ilichcorcegatreep - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 71
今までの合計 20,781
