この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replace the fan in your Apple TV 1st Generation.
必要な工具と部品
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
4 の人々がこのガイドを完成させました。
