メインコンテンツにスキップ
このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
  1. この手順は未翻訳です。 翻訳を手伝う。
    : 手順 1、 1の画像 1
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. この手順は未翻訳です。 翻訳を手伝う。
    : 手順 2、 1の画像 1
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. この手順は未翻訳です。 翻訳を手伝う。
    : 手順 3、 1の画像 1
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. この手順は未翻訳です。 翻訳を手伝う。
    : 手順 4、 2の画像 1 : 手順 4、 2の画像 2
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
  5. この手順は未翻訳です。 翻訳を手伝う。
    : 手順 5、 1の画像 1
    • The fan is held in place by three rubber posts.
    • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
    • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
    • Do not excessively pull on the posts, as they may rip.
  6. この手順は未翻訳です。 翻訳を手伝う。
    : 手順 6、 1の画像 1
    • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
    • Lift and remove the fan out of the upper case.
ゴール
4 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
ropel
メンバー登録日: 11/11/09
113 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 18-5, Maness Fall 2009 Cal Poly, Team 18-5, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S18G5
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 23
今までの合計 11,846
