この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The LCD main board is the backbone of the Apple Studio Display M2454. It accepts the information coming from the computer and transmits this data to the screen to form an image. The main board is also wired into the USB ports on the back of the monitor and other circuitry. There are many connections but replacing this board is relatively easy.
必要な工具と部品
Locate the four hex head screws located on the corners of the back panel.
Remove the screws with a 2mm hex screwdriver.
ある他の人がこのガイドを完成しました。
