Now remove the back panel under the clear cover.
Again, feed the cable through the panel so no damage occurs.
To remove the metal plate covering the circuitry you need to push the cover towards the base of the monitor.
If done correctly the tabs holding the plate should be detached and the plate will easily pop off.
Locate the four phillips head screws on the corners of the board.
Using the phillips head screwdriver, remove the four screws holding the board to the monitor.
Remove the other two connectors by raising the tab on each either by hand or using a flat ended tool as shown.
Then gently pull away from the board to release tabs.
The tabs can easily break off, be extra careful.
Remove the final black connector by pressing down on the back of the tab on the connector and then pull away from the board.
Be careful when holding onto the board while removing this connector or you risk pulling the board away too quickly and damaging the connector.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
