メインコンテンツにスキップ
Apple AirPort Extreme Model A1034 USB Port Replacement
必要な工具と部品
  1. Apple AirPort Extreme Model A1034 USB Port Replacement, Outer Case: 手順 1、 1の画像 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 2、 1の画像 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 3、 2の画像 1 Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 3、 2の画像 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 4、 1の画像 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 USB Port Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 6、 1の画像 1
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 7、 1の画像 1
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 8、 2の画像 1 Apple AirPort Extreme Model A1034 USB Port Replacement: 手順 8、 2の画像 2
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
  9. Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: 手順 9、 2の画像 1 Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: 手順 9、 2の画像 2
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Michael Garcia
メンバー登録日: 10/12/11
411 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G15
3 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 3,148
