メインコンテンツにスキップ
Apalus Digital Hair Straightening Brush LCD Screen Replacement
必要な工具と部品
  1. Apalus Digital Hair Straightening Brush LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 2、 1の画像 1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 3、 1の画像 1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 5、 1の画像 1
    • Locate the LED screen on the top side of the circuit board
  6. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 6、 1の画像 1
    • Flip the circuit board to start soldering.
  7. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 7、 2の画像 1 Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 7、 2の画像 2
    • Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
    • The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
    • Soldering Technique Guide
  8. Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 8、 2の画像 1 Apalus Digital Hair Straightening Brush LCD Screen Replacement: 手順 8、 2の画像 2
    • Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
    • Solder at the same 11 points where you previously melted to remove the screen.
終わりに
作成者
2人の作成者と共同で作成されました。
Malak
メンバー登録日: 11/06/17
101 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G3, Harley Fall 2017 IUPUI, Team S1-G3, Harley Fall 2017人のメンバー
IUPUI-HARLEY-F17S1G3
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 497
