メインコンテンツにスキップ
Aoson R103 Speakers Replacement
必要な工具と部品
  1. Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: 手順 1、 3の画像 1 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: 手順 1、 3の画像 2 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: 手順 1、 3の画像 3
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Speakers Replacement: 手順 2、 2の画像 1 Aoson R103 Speakers Replacement: 手順 2、 2の画像 2
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Speakers Replacement, Speakers: 手順 3、 3の画像 1 Aoson R103 Speakers Replacement, Speakers: 手順 3、 3の画像 2 Aoson R103 Speakers Replacement, Speakers: 手順 3、 3の画像 3
    • The motherboard connections to the speaker are circled, they will be needed later.
    • The two speakers are circled in orange, they are attached to a plastic piece via a screw.
    • The 4.0mm long philips-head 00 screw will be disconnected at the Boxed area where the plastic disconnects.
    • Be careful not to disconnect the back ground wire when taking the plastic off.
  4. Aoson R103 Speakers Replacement: 手順 4、 2の画像 1 Aoson R103 Speakers Replacement: 手順 4、 2の画像 2
    • The box contains the four (4) soldering connections for the two speakers. Unsolder the old speakers and solder the new speakers in.
    • Be sure to match up the appropriately placed speaker to its correct positive or negative node. mixing these up could distort audio or fry the speakers.
    • Note: solder over a piece of paper where you can mark each node with a red or black marker to denote positive and negative nodes for the left or right speaker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Louis
メンバー登録日: 02/14/23
208 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team 3-7, Saru Jimmy Spring 2023 University of North Texas, Team 3-7, Saru Jimmy Spring 2023人のメンバー
UNT-SARU JIMMY-S23S3G7
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 150
