メインコンテンツにスキップ
Anki Cozmo Speaker Replacement
必要な工具と部品
  1. Anki Cozmo Speaker Replacement, Speaker: 手順 1、 2の画像 1 Anki Cozmo Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Remove the two black rubber treads from the wheels using your hands to pull them off.
  2. Anki Cozmo Speaker Replacement: 手順 2、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 2、 2の画像 2
    • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
    • There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
    Note: The hubcaps are the same color of your Cozmo. My Cozmo is black to gray, but the one from the creator shows a white Cozmo.
    Logan Bovan - 返信
  3. Anki Cozmo Speaker Replacement: 手順 3、 1の画像 1
    • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
  4. Anki Cozmo Speaker Replacement: 手順 4、 1の画像 1
    • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
  5. Anki Cozmo Speaker Replacement: 手順 5、 1の画像 1
    • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
  6. Anki Cozmo Speaker Replacement: 手順 6、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 6、 2の画像 2
    • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
  7. Anki Cozmo Speaker Replacement: 手順 7、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 7、 2の画像 2
    • Remove the front gold bumper using your hands and fingers to pull it off.
  8. Anki Cozmo Speaker Replacement: 手順 8、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 8、 2の画像 2
    • Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
    • One screw is towards the front wheel and one screw is towards the back wheel.
  9. Anki Cozmo Speaker Replacement: 手順 9、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 9、 2の画像 2
    • Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
    • Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
    • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
    Steps 9 and 10 contain errors that will lead to broken parts of the robot.
    The upper arms (thin) must be pry off on both sides with metal spudgers. Then remove the white axis that connects them (what is called a spring here).
    And then you need to manually rotate the lower arms to the upper position (while slightly pulling them) until the latches are aligned with the corresponding slots in the case and the arms separate from the body. No force required.
    If you remove them with metal spudgers, you will leave marks on the case and break one or more of the latches.
    Nifty - 返信
    YES this is the good method to avoid broken arm :
    Madcat -
  10. Anki Cozmo Speaker Replacement: 手順 10、 3の画像 1 Anki Cozmo Speaker Replacement: 手順 10、 3の画像 2 Anki Cozmo Speaker Replacement: 手順 10、 3の画像 3
    • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
    Nifty - 返信
  11. Anki Cozmo Speaker Replacement: 手順 11、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 11、 2の画像 2
    • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
  12. Anki Cozmo Speaker Replacement: 手順 12、 1の画像 1
    • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
  13. Anki Cozmo Speaker Replacement: 手順 13、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 13、 2の画像 2
    • Remove the right side of the white head using your hands and fingers to pull it off.
    • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
  14. Anki Cozmo Speaker Replacement: 手順 14、 1の画像 1
    • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
  15. Anki Cozmo Speaker Replacement: 手順 15、 1の画像 1
    • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
  16. Anki Cozmo Speaker Replacement: 手順 16、 2の画像 1 Anki Cozmo Speaker Replacement: 手順 16、 2の画像 2
    • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
    • The camera and the speaker are attached to each other. They are removed in the same step.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Marisa Gay
メンバー登録日: 10/28/21
702 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021人のメンバー
UMASSD-GULBRANDSEN-F21S4G8
3 メンバー
7のガイドは作成済み
2 件のコメント
Great, do you know where to buy the speaker ?
Gilberto Torres - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 83
今までの合計 2,764
