メインコンテンツにスキップ
Anker 2.4G Wireless Mouse Sensor Replacement
必要な工具と部品
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: 手順 1、 1の画像 1
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Sensor Replacement: 手順 2、 1の画像 1
    • Using your Phillips screwdriver, remove the four screws.
  3. Anker 2.4G Wireless Mouse Sensor Replacement: 手順 3、 2の画像 1 Anker 2.4G Wireless Mouse Sensor Replacement: 手順 3、 2の画像 2
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
  4. Anker 2.4G Wireless Mouse Sensor Replacement: 手順 4、 1の画像 1
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Sensor Replacement: 手順 5、 1の画像 1
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
  6. Anker 2.4G Wireless Mouse Sensor Replacement: 手順 7、 1の画像 1
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
終わりに
2 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Ryan
メンバー登録日: 01/23/14
140 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G39
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 59
今までの合計 7,179
