メインコンテンツにスキップ
Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement
必要な工具と部品
  1. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement, Outer Casing: 手順 1、 1の画像 1
    • Remove the two Phillips #00 screws:
    • One Phillips 16mm screw
    • One Phillips 14 mm screw
    • All of the hair dryer's components are held together by these two screws. Parts may quickly separate after screw removal. Tape can be used to hold everything in place.
  2. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 2、 3の画像 1 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 2、 3の画像 2 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 2、 3の画像 3
    • Remove the top portion of the handle.
    • The model information and warnings are engraved on the top portion.
  3. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 3、 2の画像 1 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 3、 2の画像 2
    • Remove the settings switch by lifting straight up.
  4. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 4、 3の画像 1 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 4、 3の画像 2 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 4、 3の画像 3
    • Remove the internal components from the rear portion of the handle.
    • Remove the switch
    • Remove the circuitboard
    • Remove the capacitor in black plastic
    • These parts are not secured to the handle by anything, but are all connected to each other by wires. They shouldn't be difficult to remove, but remember that they will come out together.
  5. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 5、 3の画像 1 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 5、 3の画像 2 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 5、 3の画像 3
    • Remove the sliding black cover at the top of the handle.
  6. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 6、 2の画像 1 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 6、 2の画像 2
    • Remove the lower portion of the handle by sliding the peg out of the slot at the top of the handle.
  7. Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 7、 2の画像 1 Andis 1875-Watt Fold-N-Go Ionic Hair Dryer Outer Casing Replacement: 手順 7、 2の画像 2
    • Separate the silver front casing from the black rear vent.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Scott Havard
メンバー登録日: 06/27/16
50,426 ポイント
31のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 21
今までの合計 2,211
