メインコンテンツにスキップ
Amazon Fire HD 10 Motherboard Replacement
必要な工具と部品
  1. Amazon Fire HD 10 Motherboard Replacement, Screen: 手順 1、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement, Screen: 手順 1、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement, Screen: 手順 1、 3の画像 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
    The right side with the power switch on top?
    Sonny Shear - 返信
    Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
    Thanks!
    Steve Ciciora - 返信
  2. Amazon Fire HD 10 Motherboard Replacement: 手順 2、 1の画像 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
    What is a ZIP connector? What does it look like?
    Beldenr - 返信
    Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
    Adam O'Camb -
  3. Amazon Fire HD 10 Motherboard Replacement: 手順 3、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 3、 2の画像 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Motherboard Replacement, Battery: 手順 5、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement, Battery: 手順 5、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement, Battery: 手順 5、 3の画像 3
    • Locate the power cable that links the battery to the motherboard.
    • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
    • The third image shows what it should look like with the battery power cable is disconnected.
    Battery removal is optional for the motherboard, but is a great addition to this guide for completeness.
    scottpickles - 返信
  6. Amazon Fire HD 10 Motherboard Replacement: 手順 6、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 6、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement: 手順 6、 3の画像 3
    • Begin by locating the double sided pull tape locations.
    • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
    • Pull the black soft tabs to release the tape's adhesion.
    • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
    • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
    Why not heating the tabs a little to take battery easier
    Engin Isleyen - 返信
  7. Amazon Fire HD 10 Motherboard Replacement: 手順 7、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 7、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement: 手順 7、 3の画像 3
    • Make sure all the adhesive is removed before trying to lift the battery from the case.
    • After the battery is totally free of any adhesion, simply lift the battery from the case.
  8. Amazon Fire HD 10 Motherboard Replacement: 手順 8、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 8、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement: 手順 8、 3の画像 3
    • Inspect battery for any leakage.
    • Please follow all U.S. regulations and laws when disposing or recycling the battery.
  9. Amazon Fire HD 10 Motherboard Replacement, Rear Facing Camera: 手順 9、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement, Rear Facing Camera: 手順 9、 2の画像 2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  10. Amazon Fire HD 10 Motherboard Replacement: 手順 10、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 10、 2の画像 2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  11. Amazon Fire HD 10 Motherboard Replacement: 手順 11、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 11、 2の画像 2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
  12. Amazon Fire HD 10 Motherboard Replacement, Front Facing Camera: 手順 12、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement, Front Facing Camera: 手順 12、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement, Front Facing Camera: 手順 12、 3の画像 3
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  13. Amazon Fire HD 10 Motherboard Replacement: 手順 13、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 13、 2の画像 2
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  14. Amazon Fire HD 10 Motherboard Replacement: 手順 14、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 14、 2の画像 2
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  15. Amazon Fire HD 10 Motherboard Replacement: 手順 15、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 15、 2の画像 2
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
  16. Amazon Fire HD 10 Motherboard Replacement, Motherboard: 手順 16、 1の画像 1
    • Lift the ZIF connector up to disconnect from the motherboard.
  17. Amazon Fire HD 10 Motherboard Replacement: 手順 17、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 17、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement: 手順 17、 3の画像 3
    • Disconnect the connectors using the plastic opening tool.
  18. Amazon Fire HD 10 Motherboard Replacement: 手順 18、 2の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 18、 2の画像 2
    • Remove the ten T5 Torx screws securing the motherboard to the case.
    • Keep the screws together in a safe place for reassembly.
    Before moving to the removal of the motherboard, there are VERY small and EXTREMELY breakable ZIF sockets for the power button and volume buttons. I didn't realize this and started to pull the motherboard out. Thankfully they disengaged but the flaps that lock them back in are nearly paper thin. Use caution, particularly when reinstalling and closing the ZIF sockets. Lastly the power button was lose in my deinstallation because I removed the screw. It's not necessary to remove that screw.
    scottpickles - 返信
  19. Amazon Fire HD 10 Motherboard Replacement: 手順 19、 3の画像 1 Amazon Fire HD 10 Motherboard Replacement: 手順 19、 3の画像 2 Amazon Fire HD 10 Motherboard Replacement: 手順 19、 3の画像 3
    • Lift and pull the motherboard down, gently, towards the case using the tweezers.
終わりに
14 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jaie Hillery
メンバー登録日: 10/07/14
1,718 ポイント
10のガイドは作成済み
チーム
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S16G6
3 メンバー
22のガイドは作成済み
6 件のコメント
Just for the record, my screws were T4, not T5.
scottpickles - 返信
Where is a reliable store to buy this motherboard?
Jimmy Lee - 返信
what you left out is the speakers are they still attached to the motherboard you get 15 points
elliott reitman - 返信
Is this the Kindle? Not the Tablet?
imbritneyedwards - 返信
I have exhausted all online searches for a new HD Fire 10.1 7 generation motherboard replacement and have not been able to locate one anywhere do you have any places you know of that sell these types of motherboards?
Thanks,
Al Silva
Al Silva - 返信
iI am tired of searching for T76N2B motherboard replacement. Any help will be much appreciated
lucas kiai - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 45
過去 30 日: 196
今までの合計 21,083
