メインコンテンツにスキップ
Amazon Echo Show 8 2nd Generation Camera Replacement
必要な工具と部品
  1. Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: 手順 1、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: 手順 1、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: 手順 1、 3の画像 3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 2、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 2、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 2、 3の画像 3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 3、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 3、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 3、 3の画像 3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 4、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 4、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 4、 3の画像 3
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: 手順 5、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: 手順 5、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: 手順 5、 3の画像 3
    • Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the screen assembly.
    • There is a screw that is not pictured in the center of the bottom two screws.
  6. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 6、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 6、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 6、 3の画像 3
    • Gently separate the speaker housing from the display assembly and set the device on a flat surface.
    • There is a cable connecting the speaker housing to the display assembly. Take care not to pull on it while separating the two parts.
    • Use a plastic spudger to pry up and remove the foam mat at the center of the silver bracket.
  7. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 7、 2の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 7、 2の画像 2
    • Use a T6 Torx screwdriver to remove the eleven 6 mm screws that secure the silver bracket.
  8. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 8、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 8、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 8、 3の画像 3
    • Use a plastic spudger to lift up the remove the silver bracket.
    • The camera is located to the left of the mother board.
  9. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 9、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 9、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 9、 3の画像 3
    • Use a T6 Torx screwdriver to remove the two 6 mm screws that secure the camera retention plate.
  10. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 10、 3の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 10、 3の画像 2 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 10、 3の画像 3
    • Use a spudger to slightly lift the camera retention plate.
    • Lift the camera retention plate up and out of the chassis.
  11. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 11、 2の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 11、 2の画像 2
    • Use the pointed end of a spudger to flip up the camera ribbon cable ZIF locking flap.
    • Pull the ribbon cable directly out of its socket.
  12. Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 12、 2の画像 1 Amazon Echo Show 8 2nd Generation Camera Replacement: 手順 12、 2の画像 2
    • Lift up the camera gently, and use the pointed end of the spudger to gently remove the thin black ribbon cable.
    • The thin tab holding is held down with adhesive. Be gentle when removing it to prevent tearing it.
終わりに
作成者
3人の作成者と共同で作成されました。
Brian Le
メンバー登録日: 02/14/24
681 ポイント
4のガイドは作成済み
チーム
University of Memphis, Team 1-3, Sneed Spring 2024 University of Memphis, Team 1-3, Sneed Spring 2024人のメンバー
UM-SNEED-S24S1G3
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 28
今までの合計 390
