メインコンテンツにスキップ
Amazon Echo Look Midframe Replacement
必要な工具と部品
  1. Amazon Echo Look Midframe Replacement, Front Panel: 手順 1、 1の画像 1
    • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
  2. Amazon Echo Look Midframe Replacement: 手順 2、 3の画像 1 Amazon Echo Look Midframe Replacement: 手順 2、 3の画像 2 Amazon Echo Look Midframe Replacement: 手順 2、 3の画像 3
    • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
  3. Amazon Echo Look Midframe Replacement: 手順 3、 1の画像 1
    • Heat the front panel with an iOpener.
    • It may help to secure the iOpener to the device.
    • Heat the device for 5-10 minutes to loosen the glue.
    • CAUTION: The iOpener and the device may be hot.
  4. Amazon Echo Look Midframe Replacement: 手順 4、 3の画像 1 Amazon Echo Look Midframe Replacement: 手順 4、 3の画像 2 Amazon Echo Look Midframe Replacement: 手順 4、 3の画像 3
    • Lever the Jimmy between the screen and the device until an opening is formed.
    • Insert opening picks to hold the opening as needed.
    • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
    • Step 3 may need to be repeated as Step 4 is time-sensitive.
  5. Amazon Echo Look Midframe Replacement: 手順 5、 2の画像 1 Amazon Echo Look Midframe Replacement: 手順 5、 2の画像 2
    • Remove the front panel by levering the spudger at the top of the device.
  6. Amazon Echo Look Midframe Replacement, Midframe: 手順 6、 2の画像 1 Amazon Echo Look Midframe Replacement, Midframe: 手順 6、 2の画像 2
    • Remove the screws from the midframe with a Torx T5 screwdriver.
    • Lift up the midframe
    • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
  7. Amazon Echo Look Midframe Replacement: 手順 7、 2の画像 1 Amazon Echo Look Midframe Replacement: 手順 7、 2の画像 2
    • Use a spudger to gently lift up the ribbon until it detaches.
終わりに
作成者
3人の作成者と共同で作成されました。
Prince Boateng
メンバー登録日: 09/12/23
88 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 2-5, Harold Fall 2023 University of North Texas, Team 2-5, Harold Fall 2023人のメンバー
UNT-HAROLD-F23S2G5
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 116
