この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Follow this guide to replace the subwoofer in your device if you are experiencing any sort of audio issues.
必要な工具と部品
Remove the rubber layer beneath the device.
Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
Remove the four 8.0 mm T8 Torx screws on the lid.
Remove the lid from the device.
Remove the four 30.0 mm T8 Torx screws in the corners.
Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
ある他の人がこのガイドを完成しました。
