Remove the rubber layer beneath the device.
Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
Remove the four 8.0 mm T8 Torx screws on the lid.
Remove the lid from the device.
Use a spudger to flip up the small flap on the ZIF connector.
Gently pull the ribbon cable out of the ZIF connector.
Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
Remove the lid on top of the subwoofer.
Flip the device over and let the subwoofer fall into your hand.
The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
