メインコンテンツにスキップ
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
必要な工具と部品
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: 手順 1、 1の画像 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 手順 2、 1の画像 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: 手順 3、 2の画像 1 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: 手順 3、 2の画像 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 手順 4、 2の画像 1 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 手順 4、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 手順 5、 2の画像 1 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: 手順 5、 2の画像 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
終わりに
作成者
4人の作成者と共同で作成されました。
Ben Toland
メンバー登録日: 02/01/15
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-33, Amido Winter 2015 Cal Poly, Team 17-33, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G33
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 14
今までの合計 2,463
