メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alldaymall A88X Camera Replacement
必要な工具と部品
  1. Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: 手順 1、 3の画像 1 Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: 手順 1、 3の画像 2 Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: 手順 1、 3の画像 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Camera Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Camera Replacement, Speaker: 手順 3、 3の画像 1 Alldaymall A88X Camera Replacement, Speaker: 手順 3、 3の画像 2 Alldaymall A88X Camera Replacement, Speaker: 手順 3、 3の画像 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Camera Replacement: 手順 4、 3の画像 1 Alldaymall A88X Camera Replacement: 手順 4、 3の画像 2 Alldaymall A88X Camera Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Camera Replacement: 手順 5、 3の画像 1 Alldaymall A88X Camera Replacement: 手順 5、 3の画像 2 Alldaymall A88X Camera Replacement: 手順 5、 3の画像 3
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X Camera Replacement, Camera: 手順 6、 3の画像 1 Alldaymall A88X Camera Replacement, Camera: 手順 6、 3の画像 2 Alldaymall A88X Camera Replacement, Camera: 手順 6、 3の画像 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X Camera Replacement: 手順 7、 2の画像 1 Alldaymall A88X Camera Replacement: 手順 7、 2の画像 2
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X Camera Replacement: 手順 8、 2の画像 1 Alldaymall A88X Camera Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X Camera Replacement: 手順 9、 3の画像 1 Alldaymall A88X Camera Replacement: 手順 9、 3の画像 2 Alldaymall A88X Camera Replacement: 手順 9、 3の画像 3
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X Camera Replacement: 手順 10、 1の画像 1
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X Camera Replacement: 手順 11、 1の画像 1
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X Camera Replacement: 手順 12、 2の画像 1 Alldaymall A88X Camera Replacement: 手順 12、 2の画像 2
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
終わりに
作成者
3人の作成者と共同で作成されました。
Drhaber
メンバー登録日: 02/10/16
985 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 4-1, Lacy Spring 2016 USF Tampa, Team 4-1, Lacy Spring 2016人のメンバー
USFT-LACY-S16S4G1
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 435
