必要な工具と部品
Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
Note the touch-pad cable and status-light cable routing and peel off the cables from the keyboard bracket.
Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the keyboard bracket.
Slide and lift the keyboard along with the cables off the palm-rest assembly.
Align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
Route the keyboard cable, keyboard-backlight cable, marco-keys cable and marco-keys backlight cable through the slots on the keyboard bracket.
Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
Replace the screws that secure the keyboard bracket to the palm-rest assembly.
Adhere the touch-pad cable and status-light cable to the keyboard bracket.
Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
コメント 1 件
I find it concerning that this guide has you disconnect and reconnect the battery prior to doing anything with the keyboard.
