この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The interior back panel is required to gain access to most of the components of the phone. It isn't hard but you will need to be careful when removing the screws because they are small and easy to loose.
必要な工具と部品
Shut down the device
Flip the phone so that the screen is facing the surface you are working on
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
Using the J000 Phillips screwdriver, remove the one green 3mm screw.
