Flip the phone so that the screen is facing the surface you are working on
Aggressive prying may result in damaging the back panel or the internal contents of the phone.
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
Make sure all of the clips come undone when you pry the seam loose.
