Flip the phone so that the screen is facing the surface you are working on
Aggressive prying may result in damaging the back panel or the internal contents of the phone.
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
Make sure all of the clips come undone when you pry the seam loose.
Use the metal spudger to gently pry the control buttons from the case.
The control buttons are glued to the case and are on a computer ribbon. When removing them it is best to move between them so as to avoid damaging them.
Make sure to use a plastic opening tool or nylon spudger before attempting to use a metal spudger. Metal spudgers can potentially damage your device.
