メインコンテンツにスキップ
Alcatel One Touch Evolve 2 Front Camera Replacement
必要な工具と部品
  1. Alcatel One Touch Evolve 2 Front Camera Replacement, Back Frame: 手順 1、 3の画像 1 Alcatel One Touch Evolve 2 Front Camera Replacement, Back Frame: 手順 1、 3の画像 2 Alcatel One Touch Evolve 2 Front Camera Replacement, Back Frame: 手順 1、 3の画像 3
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 2、 1の画像 1
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 3、 1の画像 1
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 4、 3の画像 1 Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 4、 3の画像 2 Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 4、 3の画像 3
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 5、 2の画像 1 Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 5、 2の画像 2
    • Pull the rear frame off with your hands.
  6. Alcatel One Touch Evolve 2 Front Camera Replacement, Main Circuit Board: 手順 6、 2の画像 1 Alcatel One Touch Evolve 2 Front Camera Replacement, Main Circuit Board: 手順 6、 2の画像 2
    • Use a plastic opening tool to pop the speaker press-fit connector free.
    • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
  7. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 7、 1の画像 1
    • Use a plastic opening tool to lift the front camera press-fit connector free.
  8. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 8、 1の画像 1
    • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
  9. Alcatel One Touch Evolve 2 Front Camera Replacement: 手順 9、 1の画像 1
    • Detach the main circuit board from the front cover.
  10. Alcatel One Touch Evolve 2 Front Camera Replacement, Front Camera: 手順 10、 1の画像 1
    • Slip the front camera out of its designated hole.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Andrew Bai
メンバー登録日: 01/30/17
634 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017人のメンバー
IUPUI-BAECHLE-S17S1G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 332
