メインコンテンツにスキップ
Airox Legendair Battery Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
必要な工具と部品
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: 手順 1、 1の画像 1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: 手順 3、 1の画像 1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: 手順 4、 1の画像 1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: 手順 6、 1の画像 1
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: 手順 7、 1の画像 1
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: 手順 8、 1の画像 1
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: 手順 9、 1の画像 1
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: 手順 10、 1の画像 1
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: 手順 11、 1の画像 1
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
終わりに
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
作成者
3人の作成者と共同で作成されました。
Caleb Erlenborn
メンバー登録日: 04/09/20
174 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S7-G15, Paton Spring 2020 Cal Poly, Team S7-G15, Paton Spring 2020人のメンバー
CPSU-PATON-S20S7G15
3 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 402
