必要な工具と部品
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
Two 2.0 mm screws (with the bigger head)
Four 2.5 mm screws (with the smaller head)
On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
The next step is to pull out the ribbon cables connected to the motherboard.
Each ribbon cable has a sticker covering it; peel it off with tweezers.
Use tweezers to pull out the ribbon cable.
After the motherboard is removed, the buttons are visible on the side.
Use a soldering iron and a soldering wick to desolder the button. This could be tough due to the lead free solder used in the manufacturing process.
5 の人々がこのガイドを完成させました。
