メインコンテンツにスキップ
Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement
必要な工具と部品
  1. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Back Panel: 手順 1、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Back Panel: 手順 1、 2の画像 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 2、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the battery cable: 手順 3、 1の画像 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Battery: 手順 4、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Battery: 手順 4、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 5、 1の画像 1
    • Remove the battery from the laptop.
  6. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Unplug the WiFi Antenna Connectors: 手順 6、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Unplug the WiFi Antenna Connectors: 手順 6、 2の画像 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  7. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the Black WiFi Wire: 手順 7、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the Black WiFi Wire: 手順 7、 2の画像 2
    • Deroute the black wifi wire from its slot in the palm rest.
  8. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the White WiFi Wire: 手順 8、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the White WiFi Wire: 手順 8、 2の画像 2
    • Deroute the white wifi wire from the slot in the palm rest.
  9. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: 手順 9、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: 手順 9、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: 手順 9、 3の画像 3
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  10. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Right Hinge Screws: 手順 10、 1の画像 1
    • Remove the two screws from the right hinge.
  11. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 11、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 11、 2の画像 2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  12. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Left Hinge Screws: 手順 12、 1の画像 1
    • Remove the two screws from the left hinge.
  13. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 13、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 13、 2の画像 2
  14. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: 手順 14、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: 手順 14、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: 手順 14、 3の画像 3
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
  15. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Touchpad: 手順 15、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Touchpad: 手順 15、 2の画像 2
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  16. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 16、 1の画像 1
    • Pull the ribbon from the motherboard laterally off the touchpad.
  17. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 17、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  18. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 18、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 18、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 18、 3の画像 3
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  19. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 19、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 19、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 19、 3の画像 3
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
  20. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Speakers: 手順 20、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Speakers: 手順 20、 2の画像 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  21. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Speakers: 手順 21、 1の画像 1
    • Pry the right speaker up with your hand to remove.
  22. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 22、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 22、 2の画像 2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  23. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 23、 1の画像 1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
  24. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: 手順 24、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: 手順 24、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: 手順 24、 3の画像 3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  25. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 25、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 25、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 25、 3の画像 3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  26. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 26、 1の画像 1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  27. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Motherboard: 手順 27、 1の画像 1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
  28. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED Cable: 手順 28、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED Cable: 手順 28、 2の画像 2
    • Flip up the latch on the cable going from the I/O board to the LED board.
  29. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 29、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 29、 2の画像 2
    • Grasp the ribbon cable and pull it straight out to the right.
  30. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Motherboard Cable: 手順 30、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Motherboard Cable: 手順 30、 2の画像 2
    • Flip up the latch on the cable from the I/O board to the motherboard.
  31. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 31、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 31、 2の画像 2
    • Grasp the ribbon cable by the blue plastic reinforcement and pull the cable straight out to the right.
  32. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Retaining Screw: 手順 32、 1の画像 1
    • Remove the single screw securing the I/O board.
  33. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 33、 1の画像 1
    • Remove the I/O board.
    • When reinstalling, be sure the hinge goes above the I/O board, not below it.
  34. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the LED board: 手順 34、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the LED board: 手順 34、 2の画像 2
    • Flip the retaining latch up with a spudger.
  35. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 35、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: 手順 35、 2の画像 2
    • Pull the cable straight out away from the front of the computer.
  36. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: 手順 36、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: 手順 36、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: 手順 36、 3の画像 3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
  37. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: 手順 37、 3の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: 手順 37、 3の画像 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: 手順 37、 3の画像 3
    • The cable between the I/O board and the motherboard is lightly adhered to the plastic insulator on the keyboard. Pull up from the right to free the cable from the adhesive.
  38. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED cable: 手順 38、 2の画像 1 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED cable: 手順 38、 2の画像 2
    • The LED cable runs from the LED board to the I/O daughter card. It is lightly adhered to the keyboard. Remove it by gently pulling it away from the keyboard.
  39. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard has been removed: 手順 39、 1の画像 1
    • All components have now been removed from the keyboard / palm rest assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jerry Wheeler
メンバー登録日: 03/21/22
72,362 ポイント
71のガイドは作成済み
チーム
Oregonians Oregonians人のメンバー
Community
8 メンバー
191のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 366
