この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you successfully remove the microphone out of your Acer Chromebook Spin 15 CP315-1H-P1K8. If the microphone component for this laptop is not functioning, use this guide to properly remove the faulty microphone for replacing.
必要な工具と部品
Flip the computer over so that the back is facing up.
Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
