Make sure the device is fully powered off.
Flip the computer over so that the back is facing up.
Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
Use the iFixit opening tools as wedges to pry the back of the laptop off.
Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
Unplug the camera/microphone ribbon cable from the circuit board.
Remove the single 3mm Phillips #1 screw from the Intel core.
Unplug the cable from the circuit board.
Use the plastic opening tool, create a gap between the back and front of the display.
Lift the front out with your hands.
Remove the microphone component from the rest of the computer by detaching the connected wire.
The camera component of the laptop is connected to the same wire, so remove this as well.
The camera is only held down with adhesives, so there is no need to use any tools.
Remove the microphone and camera wire out from around the display screen.
Remove the ribbon cable at the bottom of the display screen to completely free the wire.
Carefully remove the adhesive tape and take out the ribbon cable.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
