メインコンテンツにスキップ
Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement
必要な工具と部品
  1. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: 手順 1、 3の画像 1 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: 手順 1、 3の画像 2 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 2、 1の画像 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 3、 2の画像 1 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 3、 2の画像 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 4、 1の画像 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: 手順 5、 3の画像 1 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: 手順 5、 3の画像 2 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: 手順 5、 3の画像 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 6、 2の画像 1 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 6、 2の画像 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 7、 1の画像 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Trackpad: 手順 8、 1の画像 1
    • Remove the strip of tape that secures the motherboard connector to the track pad.
  9. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 9、 1の画像 1
    • Unclip the motherboard connector from the track pad.
  10. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 10、 1の画像 1
    • Remove the strip of electrical tape from across the top of the track pad.
  11. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 11、 1の画像 1
    • Remove three 4 mm JIS #0 screws from the top of the track pad.
  12. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: 手順 12、 1の画像 1
    • Lift the laptop base and the track pad will come out from the front of the laptop.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Samantha Postma
メンバー登録日: 10/15/19
1,238 ポイント
6のガイドは作成済み
チーム
Grand Valley State University, Team S1-G3, DeVasto Fall 2019 Grand Valley State University, Team S1-G3, DeVasto Fall 2019人のメンバー
GVSU-DEVASTO-F19S1G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,011
