はじめに
Low quality or old thermal compound can lead the CPU to overheat, which slows down performance and also shortens the life of the device. Follow this guide for detailed instructions on how to access and replace the thermal compound.
必要な工具と部品
Position the computer so the opening side faces you.
Remove the four 2.5-mm screws using a PH0 screwdriver.
もう少しです!
終わりに
