このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Unfold the laptop so that you are looking at the keyboard.
At the top right of the keyboard you will notice two clips above the 'Del' and 'End' keys.
Using your spudger, press these clips in to unlock the keyboard from the laptop
Slide the spudger along the top of the keyboard until the keyboard is able to easily be lifted up out of the laptop
この手順は未翻訳です。 翻訳を手伝う。
Remove the 3 Phillips #0 screws from the fan bracket.
Lift the fan up and place it back down above the heatsink.
The motherboard can be lifted from the side and and then to the right to free the I/O port from the enclosure. Some force may be required to release the heatsink.
この手順は未翻訳です。 翻訳を手伝う。
Rotate the motherboard to the right and lay it down so that the copper heatsink is facing up and parallel with the bottom of the monitor.
In this position the last cable to the motherboard can be disconnected using the spudger to push each end out until loose enough to pull the cable completely out.
The motherboard can now be completely removed from the laptop enclosure.
この手順は未翻訳です。 翻訳を手伝う。
Remove the 4 Phillips #0 screws from the heat sink.
The heat sink can now be removed from the motherboard and CPU.
Follow this great guide to re-apply your thermal paste- 放熱グリスの塗布方法
3 の人々がこのガイドを完成させました。
