この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
After removing the Secondary Board on your device you should be exposed to the speaker. Now you are able to remove them. As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
必要な工具と部品
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
