if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
Do not kink the ribbon cables as they can break easily
Remove all 9 of the 1.5mm #00 Philips screws
Gently lift the battery out of the device
Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
The removing of the ribbon cable is done in the same way as the front facing camera.
Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
Gently lift the daughter board from the device
Using the #00 Phillips head screwdriver, remove the 1.5mm screws
Gently lift up the second speaker to remove it from the device
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
