はじめに
Although it is extremely rare, the charging port on the laptop could be defective, misaligned, or broken if the laptop fails to show any signs of receiving power.
This guide should act like a "last resort" if all other methods of charging the laptop fails.
Please note that the use of soldering is required in order to remove the old charging port from the motherboard.
必要な工具と部品
Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
手順5 Motherboard
注意: 手順 5-6 は、作業進行中としてマークされている ガイド から引用されています。
When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
