必要な工具と部品
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
Remove the three Phillips #0 screws holding the the hard drive in place:
Two 3.8 mm screws.
One 5.7 mm screw.
Remove the black tape securing the keyboard ribbon cable to the display connector.
Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
Remove the two screws securing the hinge on the left.
Pry the hinge up by hand to a 90 degree angle.
Lift the base of the laptop from the front.
Raise it to a 90 degree angle.
Slide it forward slightly to clear the hinges.
The display is now free.
Disconnect the I/O Board ribbon cable from the motherboard.
Flip up the retaining latch with a spudger.
Grasp the SSD by the sides and slide it out of the connector.
Unplug the fan.
Grasp the plug with a fingernail on either side and pull it straight out from the connector.
Remove the two 5 mm screws securing the fan.
Remove the four 3 mm screws securing the heat sink.
Place a spudger on the ears on either side of the keyboard ribbon cable connector and push evenly on both sides to release it.
Lift it slightly to relieve the tension.
Lift and slide the motherboard toward the hard drive to clear the connectors on the opposite side from the case.
