メインコンテンツにスキップ
ASUS TUF Dash F15 SSD Replacement
必要な工具と部品
  1. ASUS TUF Dash F15 SSD Replacement, Unfasten the lower case: 手順 1、 3の画像 1 ASUS TUF Dash F15 SSD Replacement, Unfasten the lower case: 手順 1、 3の画像 2 ASUS TUF Dash F15 SSD Replacement, Unfasten the lower case: 手順 1、 3の画像 3
    • Remove the 14 Phillips screws securing the lower case:
    • Seven 8.8 mm screws
    • Seven 10.1 mm screws
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. ASUS TUF Dash F15 SSD Replacement, Insert an opening pick: 手順 2、 2の画像 1 ASUS TUF Dash F15 SSD Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
  3. ASUS TUF Dash F15 SSD Replacement, Release the clips: 手順 3、 3の画像 1 ASUS TUF Dash F15 SSD Replacement, Release the clips: 手順 3、 3の画像 2 ASUS TUF Dash F15 SSD Replacement, Release the clips: 手順 3、 3の画像 3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Repeat this process along the perimeter of the lower case to release the remaining clips.
  4. ASUS TUF Dash F15 SSD Replacement, Remove the lower case: 手順 4、 3の画像 1 ASUS TUF Dash F15 SSD Replacement, Remove the lower case: 手順 4、 3の画像 2 ASUS TUF Dash F15 SSD Replacement, Remove the lower case: 手順 4、 3の画像 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. ASUS TUF Dash F15 SSD Replacement, Reposition the tape: 手順 5、 2の画像 1 ASUS TUF Dash F15 SSD Replacement, Reposition the tape: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Use tweezers or your fingers to peel back the tape on the battery connector.
  6. ASUS TUF Dash F15 SSD Replacement, Disconnect the locking bar: 手順 6、 2の画像 1 ASUS TUF Dash F15 SSD Replacement, Disconnect the locking bar: 手順 6、 2の画像 2
    • Use the flat end of a spudger to gently push the locking bar away from the battery connector.
    • Make sure the locking bar is not covering the battery connector, or you may damage the battery connector's socket in the next step.
  7. ASUS TUF Dash F15 SSD Replacement, Disconnect the battery: 手順 7、 3の画像 1 ASUS TUF Dash F15 SSD Replacement, Disconnect the battery: 手順 7、 3の画像 2 ASUS TUF Dash F15 SSD Replacement, Disconnect the battery: 手順 7、 3の画像 3
    • Insert the pointed end of a spudger under the battery connector.
    • Pry under the left edge of the battery connector to disconnect the left side of the connector.
    • Repeat this procedure for the right side of the connector.
  8. ASUS TUF Dash F15 SSD Replacement, Unfasten the SSD: 手順 8、 2の画像 1 ASUS TUF Dash F15 SSD Replacement, Unfasten the SSD: 手順 8、 2の画像 2
    • Use a Phillips screwdriver to remove the 4.2 mm screw securing the SSD.
  9. ASUS TUF Dash F15 SSD Replacement, Remove the SSD: 手順 9、 3の画像 1 ASUS TUF Dash F15 SSD Replacement, Remove the SSD: 手順 9、 3の画像 2 ASUS TUF Dash F15 SSD Replacement, Remove the SSD: 手順 9、 3の画像 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
終わりに
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
155,120 ポイント
1,033のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,788のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 44
過去 30 日: 164
今までの合計 6,591
