はじめに
If the trackpad on your Asus Q302L no longer works or gets broken you may want to replace the trackpad. This guide will take you through the steps of replacing your touchpad. Common errors with the trackpad include a drifting cursor with no input, incorrectly tracked input, or not tracking input at all, so if you experience any of these issues a touchpad replacement may alleviate your problems.
Before starting this replacement, make sure you've read the Asus Q302L troubleshooting guide to verify that the touchpad needs to be replaced. There are fragile ribbon connectors being removed in this guide, so proceed with caution!
必要な工具と部品
Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
Peel back the adhered strip to expose the black and white connections.
Pop the connections off the fixtures.
Carefully disconnect the ribbon connector from the touchpad using an iFixit opening tool.
Slowly peel the grounding strap off of the touchpad.
Use a Phillips #0 screwdriver to remove the three 2 mm screws holding the touchpad.
