メインコンテンツにスキップ
ASUS Q302L Keyboard Replacement
必要な工具と部品
  1. ASUS Q302L Keyboard Replacement, Back Case: 手順 1、 1の画像 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Keyboard Replacement: 手順 2、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 2、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 2、 3の画像 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Keyboard Replacement: 手順 3、 1の画像 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Keyboard Replacement, Battery: 手順 4、 1の画像 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Keyboard Replacement: 手順 5、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 5、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 5、 3の画像 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Keyboard Replacement: 手順 6、 2の画像 1 ASUS Q302L Keyboard Replacement: 手順 6、 2の画像 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Keyboard Replacement, Hard Drive: 手順 7、 2の画像 1 ASUS Q302L Keyboard Replacement, Hard Drive: 手順 7、 2の画像 2
    • Unplug the hard drive from the connector.
    • Use a Philips #0 screwdriver to remove all four 5mm screws holding the hard drive metal mounting bracket.
  8. ASUS Q302L Keyboard Replacement: 手順 8、 1の画像 1
    • Use a Phillips #0 screwdriver and remove the four 5mm screws on both sides connecting the Hard Drive to the mounting bracket.
    • Remove the Hard Drive from mounting bracket.
  9. ASUS Q302L Keyboard Replacement, Fan: 手順 9、 2の画像 1 ASUS Q302L Keyboard Replacement, Fan: 手順 9、 2の画像 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  10. ASUS Q302L Keyboard Replacement: 手順 10、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 10、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 10、 3の画像 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  11. ASUS Q302L Keyboard Replacement: 手順 11、 2の画像 1 ASUS Q302L Keyboard Replacement: 手順 11、 2の画像 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
  12. ASUS Q302L Keyboard Replacement, Motherboard: 手順 12、 3の画像 1 ASUS Q302L Keyboard Replacement, Motherboard: 手順 12、 3の画像 2 ASUS Q302L Keyboard Replacement, Motherboard: 手順 12、 3の画像 3
    • Peel back the adhered strip to expose the black and white connections.
    • Pop the connections off the fixtures.
  13. ASUS Q302L Keyboard Replacement: 手順 13、 2の画像 1 ASUS Q302L Keyboard Replacement: 手順 13、 2の画像 2
    • Grasp the plastic tab of each connector with your fingers.
    • Firmly pull up, releasing the connectors one at a time.
  14. ASUS Q302L Keyboard Replacement: 手順 14、 2の画像 1 ASUS Q302L Keyboard Replacement: 手順 14、 2の画像 2
    • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
  15. ASUS Q302L Keyboard Replacement: 手順 15、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 15、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 15、 3の画像 3
    • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
    • Gently apply upward pressure evenly across the length of the tab.
    • Once the tab has snapped backwards, remove the blue ribbon.
  16. ASUS Q302L Keyboard Replacement: 手順 16、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
  17. ASUS Q302L Keyboard Replacement: 手順 17、 2の画像 1 ASUS Q302L Keyboard Replacement: 手順 17、 2の画像 2
    • Lift the Hinge gently up.
    • Lightly grasp the motherboard.
    • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
    • Place new thermal paste beneath the heatsink on the new motherboard.
  18. ASUS Q302L Keyboard Replacement, Trackpad: 手順 18、 3の画像 1 ASUS Q302L Keyboard Replacement, Trackpad: 手順 18、 3の画像 2 ASUS Q302L Keyboard Replacement, Trackpad: 手順 18、 3の画像 3
    • Carefully disconnect the ribbon connector from the touchpad using an iFixit opening tool.
    • Slowly peel the grounding strap off of the touchpad.
    • Use a Phillips #0 screwdriver to remove the three 2 mm screws holding the touchpad.
  19. ASUS Q302L Keyboard Replacement: 手順 19、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 19、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 19、 3の画像 3
    • Carefully lift and slide the touchpad towards the hinges using an iFixit opening tool.
    • Remove the touchpad.
  20. ASUS Q302L Keyboard Replacement, Keyboard: 手順 20、 3の画像 1 ASUS Q302L Keyboard Replacement, Keyboard: 手順 20、 3の画像 2 ASUS Q302L Keyboard Replacement, Keyboard: 手順 20、 3の画像 3
    • Remove the three 4 mm screws using a Phillips #0 screwdriver from the right side hinge.
    • Removal of the right hinge will allow you to remove the display from the keyboard.
  21. ASUS Q302L Keyboard Replacement: 手順 21、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 21、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 21、 3の画像 3
    • Carefully, remove the ribbon connector from the power display circuit board using the iFixit opening tool.
    • Use a Phillips #0 screwdriver to remove the one 4 mm screw on the circuit board.
    • Remove the power display circuit board.
  22. ASUS Q302L Keyboard Replacement: 手順 22、 3の画像 1 ASUS Q302L Keyboard Replacement: 手順 22、 3の画像 2 ASUS Q302L Keyboard Replacement: 手順 22、 3の画像 3
    • Remove the ribbon connector from the power button circuit board using the iFixit opening tool.
    • Use the Philips #0 screwdriver to remove the two 4 mm screws on the circuit board.
    • Remove the circuit board.
  23. ASUS Q302L Keyboard Replacement: 手順 23、 1の画像 1
    • Replace keyboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Phillip Wellons
メンバー登録日: 09/27/19
109 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 860
