はじめに
This guide will help you replace the headphone jack on the ASUS MeMo Pad FHD10. The purpose of replacing the headphone jack is because you cannot hear music using your headphones or the device does not recognize your headphones when connected.
The ASUS MeMo Pad FHD10 is a 10.1" tablet and the headphone part installed in the device is a 3.5 mm jack. When you are ready to begin the replacement, please unplug the charger, turn off the device and remove the memory card. Additionally, please refer to iFixit's guide on soldering and desoldering, as you will be using a soldering iron to remove the headphone jack from the motherboard of the device.
必要な工具と部品
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
この手順で使用する道具:Desoldering Pump$3.99
Using a soldering gun, desolder the headphone jack from the motherboard at each connection to the motherboard.
