はじめに
Many people will dump a laptop if the screen is broken, but this laptop's screen is replaceable! This guide will walk you through how to remove your screen module so that it may be replaced.
必要な工具と部品
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
この手順で使用する道具:Tweezers$4.99
Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
Disconnect the three cables attached to the motherboard.
The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
Carefully free up the black and white RF cables that are running along the laptop casing and speaker housing.
