メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS D550MA-DS01 DVD Drive Replacement
必要な工具と部品
  1. ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: 手順 1、 2の画像 1 ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: 手順 1、 2の画像 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
    FixBotに聞いてみる
    コメントを追加
  2. ASUS D550MA-DS01 DVD Drive Replacement: 手順 2、 1の画像 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
    FixBotに聞いてみる
    コメントを追加
  3. ASUS D550MA-DS01 DVD Drive Replacement: 手順 3、 2の画像 1 ASUS D550MA-DS01 DVD Drive Replacement: 手順 3、 2の画像 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    FixBotに聞いてみる
    コメントを追加
  4. ASUS D550MA-DS01 DVD Drive Replacement: 手順 4、 1の画像 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
    FixBotに聞いてみる
    コメントを追加
  5. ASUS D550MA-DS01 DVD Drive Replacement: 手順 5、 1の画像 1
    • Remove the fully disconnected keyboard module from the laptop.
    FixBotに聞いてみる
    コメントを追加
  6. ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: 手順 6、 2の画像 1 ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: 手順 6、 2の画像 2
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  7. ASUS D550MA-DS01 DVD Drive Replacement: 手順 7、 1の画像 1
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Richard Johnson
メンバー登録日: 09/16/15
707 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 1-2, Baechle Fall 2015 IUPUI, Team 1-2, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S1G2
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 30
今までの合計 853
