はじめに
The CMOS battery ensures that BIOS settings stay when your computer powers off. If the settings keep getting reset or the system time keeps changing, then it may be time to replace the CMOS battery.
必要な工具と部品
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
この手順で使用する道具:Tweezers$4.99
Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
Disconnect the three cables attached to the motherboard.
The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
