メインコンテンツにスキップ
AEG Electrolux FM72 Disassembly for cleaning
必要な工具と部品
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 手順 1、 3の画像 1 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 手順 1、 3の画像 2 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: 手順 1、 3の画像 3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 手順 2、 3の画像 1 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 手順 2、 3の画像 2 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: 手順 2、 3の画像 3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: 手順 3、 3の画像 1 AEG Electrolux FM72 Disassembly for cleaning: 手順 3、 3の画像 2 AEG Electrolux FM72 Disassembly for cleaning: 手順 3、 3の画像 3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: 手順 4、 2の画像 1 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: 手順 4、 2の画像 2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
終わりに
3 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Kevin D
メンバー登録日: 05/02/14
7,418 ポイント
21のガイドは作成済み
3 Guide Comments
Hello
How can i repair the electric wire on this device please ?
Heloise - 返信
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - 返信
How can I disassemble the motor parts for cleaning?
wongkapo0611 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 55
今までの合計 6,971
