はじめに
If you notice your ACER Aspire V5(571P-6609) doesn’t hold a charge or doesn't charge at all, you may consider replacing the battery. The battery stores and delivers energy to your laptop. Batteries degrade over years of continuous use and charging cycles. If you have determined the battery is faulty, replacing it is straightforward. A swollen or punctured battery can cause fires. Make sure to take the necessary safety measures. Before you begin the battery replacement power off your laptop completely.
必要な工具と部品
Place the laptop facing down and find the slider close to the battery.
Use a screwdriver or other pointed tool to slide it to the right.
No Reassembly Required
