メインコンテンツにスキップ
2011-2013 Scion tC Mid-Range Door Speaker Replacement
必要な工具と部品
  1. 2011-2013 Scion tC Mid-Range Door Speaker Replacement, Mid-Range Door Speaker: 手順 1、 1の画像 1
    • Using plastic pry tool. Pry silver cover from handle.
  2. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 2、 1の画像 1
    • Using plastic pry tool. Pry Control panel off which controls locking, unlocking and windows.
  3. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 3、 1の画像 1
    • Un-attach white header(connector) from control panel. Push side tab on side of white connector if a little stuck.
  4. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 4、 1の画像 1
    • Using pry tool. Pry off plastic plate in section of door lock or pull handle.
  5. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 5、 1の画像 1
    • Remove the #4 25mm screw and the #2 25mm screw on panel with a standard Phillips Screwdriver.
  6. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 6、 1の画像 1
    • Pry Off Full Door Panel starting at bottom and working up the side, pulling fairly hard waiting. Clicking noises are a good sign the door panel is unlocking.
  7. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 7、 1の画像 1
    • Once door panel is free, remember to remove header from the tweeter in upper right hand corner of panel.
  8. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 8、 1の画像 1
    • Remove bracket from door by unscrewing the two 14 mm nuts pictured here connected to the speaker unit.
  9. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 9、 1の画像 1
    • Remove speaker from bracket by unscrewing the two #2 12mm screws using a Phillips head screwdriver.
  10. 2011-2013 Scion tC Mid-Range Door Speaker Replacement: 手順 10、 1の画像 1
    • Desolder wires to new speaker unit using solder wick or a desoldering tool.
    • If you don't have experience soldering, make sure to check out this soldering guide.
    • Soldering uses high temperatures. Be careful not to damage the components or injure yourself in the process.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
sdwelsh
メンバー登録日: 05/04/15
187 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015人のメンバー
CPSU-REGAN-S15S8G2
5 メンバー
7のガイドは作成済み
コメント 1 件
Are they 6.5 subwoofer lower door or 6×9
pauliemcfly25 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 34
今までの合計 3,860
