メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
Bottom case swap between late-08 to mid-09 A1286?
I bought a mid-09 MBP to replace my late-08 that had an unfortunate accident with a bottle of Pepsi last year. This new computer has the solid base, as opposed to the one on my late-08 model which had the battery door. Can I swap the old battery door-having base onto the newer mid-09 model?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
No - The "Mid-2009" models have a built-in non-swappable battery design -- like the previously introduced and subsequently discontinued MacBook Pro "Core 2 Duo" 2.66 17-Inch (Unibody) -- and this battery is not designed to be removed or serviced by end users. The battery is completely different to the point even with a "door" you couldn't swap it. I doubt other internal components would line up/fit the older bottom.
If this answer was helpful please remember to mark it accepted.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
That's what I needed to know.
[sarcasm] Gotta love Apple and their "we're not going to allow you to work on it" mentality. [/sarcasm] Hence why I love this site so much.
さんによる
Apple has gone the way of many industries (auto for example) DIYers are not capable of repairing products, and many parts are not designed with repair in mind (it's not cost efficient), the soluiton is to just replace/discard entire components.
さんによる
コメントを追加
回答を追加する
David Jonas さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 3
今までの合計 563
